Angle Dimension Witness Lines
Zdenko
how do i get angle dimension to show a horizontal witness line for the angle call out for 18.43 & 39.81?
Operating system used: Mac Apple Silicon Sonoma 14.5
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
6 REPLIES 6
What settings do you have for your witness lines?
i thought all options were attempted on my end and went back to create your screen capture. however, still nothing?
Sequoia 15.1.1
The 'dynamic height' option for the witness line does not seem to work when there is no second line to measure the angle.
You are just picking a point along a guide line and it does not seem to like that.
Change to the 'custom heght' option.
thanks for the input and did try dynamic but still is not cooperating or i probably can't figure it out. will do the old fashioned way.
Sequoia 15.1.1
What settings are you using and what problems do you have.
Images help a lot.
Zdenko
hi @LiamHarris & @Barry Kelly i don't bother with it anymore, nowadays i just manually place lines with line styles on plans.
Sequoia 15.1.1
Setup info provided by author
