ArchiCAD 20 Updated Text
Has anyone else, after updating to ArchiCAD 20, had the issue of typing text and when you're finished it automatically resizes itself much smaller to the point you can't read it? Not sure if there's a new setting we need to adjust or if this is a bug.
15 REPLIES 15
Same here with ArchiCAD 20 Build 3016 MacOSX 10.11
Fast moving of the mouse or any premature Action on the keyobard after hitting enter shrinks text to 0.1.
Can be avoided (In my case) when not moving the mouse and waiting ca. 2,0 seconds after hitting enter when text is finished.
Something quite similar happens when typing values into the tracker, hitting enter and hitting Esc too fast afterwards, the value then suddenly jumps always up to 100.
Empiric testing found out that this must have to do something with the mouse / keyoboard doubleclick Speed because reducing the doubleclick intervalls of the mouse significantly reduced text shrinking events.
Trackerproblem with esc key stays the same though as i have no possibility to change the keyboard settings.
A solution or at least explanation of the support would be appreciated.
This was apparently resolved in the last hotfix -- 5025. (At least in the International version. If you have the German version, you will have to wait a little, since it's not out yet.)
Richard
AC26 (since AC6.0), Win10
Dear Richard,
thanks for your reply.
When the update is out i will keep you updated if it works.
Has anyone resolved this problem? Thanks
Do you have the latest build 5025?
It is available for AUS.
I have never seen this issue myself but I certainly can't reproduce it in build 5025 when I try.
Dave Jochum
Problem still exists despite several new builds since first reported.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
