clauds1223
Fit to text option
Hi there,
I was wondering if there is a way to quickly fit textbox to text in archicad instead of manually changing it everytime?
3 Replies 3
Karel Landa
Just uncheck the "wrap up text" button in the settings and click OK.
After that, the frame will resize to create one long text line.
From Archicad 17
MacBook Pro M1 Max
Stefan L_
And doubleclicking the same point as the text start helps a lot too. 😉
Stefan - AC ...-30GER, WIN11
Karel Landa
This is great when you create the text but if you already have one which you would like to resize or you import something where it does not meet your expectations, this will do the trick  😉
From Archicad 17
MacBook Pro M1 Max
