a month ago
Hi there,
I was wondering if there is a way to quickly fit textbox to text in archicad instead of manually changing it everytime?
a month ago
- last edited
a month ago
Just uncheck the "wrap up text" button in the settings and click OK.
After that, the frame will resize to create one long text line.
a month ago
And doubleclicking the same point as the text start helps a lot too. 😉
a month ago
This is great when you create the text but if you already have one which you would like to resize or you import something where it does not meet your expectations, this will do the trick 😉
