We value your input!
ArchiCad 10 Layout to PDF
I have a problem with printing layouts from ArchiCad 10. The new version has incorporated Plotmaker. In version 9 one could save the layouts as Plot files to Plotmaker and then in Plotmaker there was a preference in the print command that allowed you to print the entire layout book, or save it as one PDF file. In ArchiCad 10 I can only save or print as a series of indivdual PDF files. As much as I hated Plotmaker, (on OS X it tended to crash everytime I used it), this one feature was great.
Am I missing something?
1 REPLY 1
If I am understanding your problem correctly, you can publish PDF to a single file. In Organiser, create (or drag) a folder with the layouts you wish to publish into your publisher sets side, select the folder and change format to PDF, click on the "Merge to one PDF file" button.
A separate issue but slightly related, the "print entire layout book" option has gone, but you can select all the layouts you want and "print selected layouts" from the print dialogue.
HTH
