2021-08-20 12:48 AM - last edited on 2023-05-30 12:21 PM by Rubia Torres
2021-09-17 03:54 PM
Thank you very much for the report and I am very sorry about the issue!
This was a known defect, recorded as DEF-3025.
The position of the label is not correct if the autotext appears on the first line of the label. Unfortunately, the only workaround is to connect the point with Box instead of with First Row.
Due to the low priority and the complexity of the fix, it is being scheduled to Update 3 for Archicad 25. I am very sorry for the inconvenience, and thank you very much for your understanding!
Please let me know if you have any further questions!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-10-19 07:56 PM - edited 2021-10-19 07:58 PM
Just FYI - We are also affected by this issue. It does not seem to matter where the Autotext occurs in the label.
What is the schedule for Update 3?
