Zeljko
Archicad 26 crashes when opening layout book.
Archicad 26 crashes every time I try to open layout book. It doesn't matter if file is empty or there are some drawings in it. My Archicad is up-to-date.
BUG ID: ac26-2022-10-12-09-43-29-2073
4 Replies 4
Had such case with first Archicad 25 - 3001 release when having ~3000 layouts. Always crashed. In later version it was fixed.
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
Make sure you contact your local support and quote that bug ID.
Don't rely that someone from Graphisoft will find it here.
So the same happens even when you open the default template that comes with Archicad?
Zeljko
Thank you for the suggestion. I will contact them.
No, actually when I open it with the default template it works just fine, no crashing.
That makes me think the problem is in your file.
Maybe save a copy of the file.
Delete all of the layouts, maybe the masters as well.
Now recreate new blank ones and see if that has the same trouble.
If not start adding some drawings (views).
Basically it is just going to be a game of trying to find what is causing the problem.
