Archicad into photoshop
I have saved my plans as a PDF in archicad but when they are place in a photoshop page they appeared blurred. Is there a better file format to save them in?
Thanks
Deb
3 Replies 3
Steve Jepson
I think the .pdf is best. However, it could be that if you used ArchiCAD to Publish your layouts as .pdf's that they are of very low resolution. You can change that in Publisher settings if you think that might help. ?
Haneef Tayob
We often use Acrobat Pro to convert our pdf's into high resolution tiff's.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Thanks Haneef and Steve.
Deb
