2024-06-20 12:00 PM - edited 2024-06-20 12:30 PM
I am reading online about add-on area list to calculate the areas according to DIN 277 , but can´t fin anywhere how to download it. I check on the website of Graphisoft and forums, and there is nothing about it. Is this Add-on still available? Here is the link where is explained what the add-on does: https://help.graphisoft.com/AC/26/INT/_AC26_Help/930_ExtraTopics/930_ExtraTopics-1.htm
2024-06-24 06:27 PM
If you go up to its parent topic in the Help File:
it says:
Functions in this section may not be available in all markets.
From the screenshots, I suspect this Area Add-On is available only in German-speaking countries.
2024-06-25 12:00 PM
I work in Germany but I have the INT version of Archicad. But my colleagues have the German version of Archicad, so I guess I will try to get in their Archicad and try find the add-on in the help tab. But I found strange that nothing else appear online about this add-on, not even in German language. If someone from Germany reads this, please let me know if you know something.
2024-06-25 01:38 PM
In Belgium we also have this module certainly because of the proximity.
In my opinion it is enough to copy from the German version the folder (List Areas Templates) and the file (List Aeras) which are located in the Archicad xx - Extensions folder
2024-06-25 03:34 PM
This addon will not work in the INT version. It is a pity that there is still this limitation between the localized versions even for the official addons by Graphisoft.
