go
maurotrotta
since ‎2023-10-13
‎2025-06-19
User Statistics
  • 66 Posts
  • 6 Solutions
  • 15 Likes given
  • 5 Likes received
User activity
My office computer had an update and when I try opening a file in Archicad, the file explorer that pops up doesn´t have the "quick access" folder like it used to have before the update. I have to look in hundreds of folders to find the one I need. How on earth can I fix this...
This topic was asked in 2015 but I couldn´t find a solution. I need to mark many doors as demolished, and when I do, then the opening is filled with a new wall. Then I select a door opening and place it where the filled opening is, and then I have a fill of a color that I ca...
Exactly what it said in the title of the post, I am doing a schedule displaying only areas, but the schedule insist in displaying othere elements around the boundaries of the zone: doors, walls, windows, rails, etc) even when I set the schedule to not show these elements. Wh...
I copied an object of one file and pasted into another, and when I tried to change some of the object settings, I get this warning message about a script in the object having a negative value. I have no idea how to fix this since I am not familiar with object´s script. Can s...
Something weird is happening with a label I created. It was working well, but suddenly the alignment went all wrong, and I can not figure out how to fix it. I want everything to be center. Here are the pics of what is happening now. Operating system used: Windows 27
