maurotrotta
Zone schedule displaying not choosed elements
Exactly what it said in the title of the post, I am doing a schedule displaying only areas, but the schedule insist in displaying othere elements around the boundaries of the zone: doors, walls, windows, rails, etc) even when I set the schedule to not show these elements. What am I doing wrong? Does it have something to do with the settings of Walls having a specific relation to zones (Reduce, Substract, etc) It is a big file, so every change and test I do takes a long time to make the schedule.
Operating system used: Windows 28
1 Solution
To add the Runxel's comment. This is probably where you should put those parentheses:
Go to post
2 Replies 2
runxel
Easy thing to memorize: As soon there is a single "OR" in the criteria you will need to set the brackets "(" / ")" accordingly.
