SOLVED!
Label aligment acting weird
maurotrotta
Something weird is happening with a label I created. It was working well, but suddenly the alignment went all wrong, and I can not figure out how to fix it. I want everything to be center. Here are the pics of what is happening now.
Operating system used: Windows 27
1 ACCEPTED SOLUTION
Solution
the only way i could recreate the error was by adding a lot of spaces following the room's name:
"Lobby                     "  instead of "Lobby". Maybe your issue might be hidden there?
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
5 REPLIES 5
How did you create the label?
Simply saved as a label or did you script it.
The problem is, because you created it, we do not have it to test.
I took an already made label, customized his settings and save it as favorite. Then I choosed other labels I wanted to change and I apply the favorite settings to them. Attached the file
maurotrotta
Just checking if someone figure this one out. Anyone?
Solution
There was a lot of blank space after the name of the Zone :S A silly mistake but toke me a lot of time to find out.
Setup info provided by author
