2024-10-15 05:13 PM - last edited on 2024-10-16 01:29 AM by Laszlo Nagy
Something weird is happening with a label I created. It was working well, but suddenly the alignment went all wrong, and I can not figure out how to fix it. I want everything to be center. Here are the pics of what is happening now.
Operating system used: Windows 27
Solved! Go to Solution.
2024-11-05 10:47 AM
the only way i could recreate the error was by adding a lot of spaces following the room's name:
"Lobby " instead of "Lobby". Maybe your issue might be hidden there?
2024-10-16 02:42 AM
How did you create the label?
Simply saved as a label or did you script it.
The problem is, because you created it, we do not have it to test.
2024-10-16 10:28 AM
2024-11-05 10:07 AM
Just checking if someone figure this one out. Anyone?
2024-11-05 10:47 AM
2 weeks ago
There was a lot of blank space after the name of the Zone :S A silly mistake but toke me a lot of time to find out.
