Cec
Area text / dimensions (Master layout book)
Why is the m2 dimensions not showing up in the master layout book page? Also, is there any tutorials / help with layers and layout book for archicad 28 anywhere? 🙂
Operating system used: Mac Intel-based Sequoia 15.2
ArchiCad 28 - Intel based
MacBook Pro 2020 2 GHz Quad-Core Intel Core i5
Sequoia 15.2
Setup info provided by author
1 Solution
Jeff Thompson
Cec, these M2 dimensions look like they are the square meter totals for fills.  Are the fill patterens layer turned on in your layer combination?
If they are turned on, then perhaps the "Show Area Text" toggle was unchecked on the all the fills.  Make sure that this is checked and then they should show up.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
Go to post
2 Replies 2
Jeff Thompson
Project Manager
Cec
thank you very much 😄
Sequoia 15.2
