ā2020-02-09
06:35 PM
ā2023-05-19
03:21 PM
Gordana Radonic
ā2020-02-10 02:46 PM
ā2020-02-11 01:45 AM
ā2020-02-11 06:45 PM
ā2020-02-11 11:18 PM
ā2020-02-12 02:00 AM
ā2020-02-12 11:24 AM
ā2020-02-12 06:04 PM
ā2020-02-18 11:25 AM
ā2020-02-18 02:28 PM
DGSketcher wrote:Hi all,
I must admit I was surprised at the hatching method. To some extent I am inclined to suggest the hatching process is a bug. The output is principally correct, but I would have expected the hatched area that is created by the roof to be treated as a cut, (which it is), and therefore use the cut fills option of the building material rather than the Vectorial Hatching. I would then have expected, having turned on the the cover fills, for the surface hatching to be applied to the other exposed surfaces of the morph. Anybody else minded that the hatch type and cover fill application is flawed?
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
