Autotext <FolderName> without Folder ID
Hi, I have a question about naming the files I export with the Publisher. I have the following code to create file names:
<SourceID>_<FolderName>_<SourceItemName>_<YEARLONG>.<MONTHNUMBER>.<DAYOFMONTH>
The problem though is that the FolderName also contains the folder ID. Can I somehow add only the folder Name without the ID?
I get this name: 5-VA.00.1_5-VA.00 Baufreigabe (<SourceID>_<FolderName>)
I want to have this name: 5-VA.00.1_Baufreigabe
If I just write FoldeName I get: 5-VA.00 Baufreigabe (the .1 for the specific layout is missing)
Is this possible without having to make a seperate Publisher set for each Folder?
Thanks
Daniel
Podolsky
Ace
Use <SUBSETNAME> instead of <FolderName>
