Black pen presentation layout
Is there a way I can keep my company colours asign in my working layout and then change to black in my presentation lay out. I found very interesting working with different colours but make the presentation with only a reduced number of colours, may be black, red and grayscale.
4 REPLIES 4
Lingwisyer
Guru
Just set your views placed on your layouts to use a different penset to the one you work with?
Ling.
When I place my views there is no option to change the pen set on the presentation layouts.
Am I missing something important?
David Maudlin
darwinland:
After placing the View on a Layout (it becomes a Drawing), select the Drawing, open its Settings and go to Size and Appearance > Pen Set:.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Lingwisyer
Guru
Right click on a view, and select View Settings at the bottom.
Ling.
