Bug splat when importing 3D document in Layout
Hello,
I made a 3D document (reflected ceiling plan), but when I import it in the Layout I created, it crashes and gives a big splat message.
All my plans, elevations, sections are fine. It seems like the 3D document is the problem ...
Please help,
Thanks a lot!
So you can open the 3D document and see what you want but you just can't add it to a layout?
If so I would create a new view (in the View Map) from the 3D Document and see if you can place that on your layout.
Don't place the 3D Document from your Project Map directly onto a layout if that is what you are trying to do.
