Builder Dimension 22 in AC23
I have been using Builder Dimension 22 in AC22. This gives me the format I want to use. In AC23, there is no option to use this marker or a 23 version. I have tried loading the 22 version into 23 and I get a message saying "this is not a valid door marker". Is there an updated version of this marker? This is the only marker I like to use.
10 Replies 10
Loren wrote:
Barry,
Where specifically is this macro?
I have no idea really.
We do not have this marker in the AUS template and library.
I was just going by what Ling had suggested - which seemed to work for Kris.
Lingwisyer wrote:
New AC22 document => Place the marker => Library Manager => [Relevant Library] => Embed Placed Objects of Selected Libraries
I believe that will save all the required macros to the Embedded Library which you can then extract to where ever it is required.
Kris has also uploaded a zip file with all that you should need in the other post.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=69636#p310073
