CAN'T SHOW THE LAYOUT SHEET NUMBER IN MY SECTION MARKS
SOME HOW IN THIS FILE I AM NOT ABLE TO SHOW THE LAYOUT SHEET NUMBER IN MY SECTION MARKS ANY IDEA WHAT IS GOING ON? ....TKS.
F.S.
4 REPLIES 4
In the screenshot you have attached, change the setting from custom to 'referred drawing'. Hope this helps.
Erika Epstein
see screen shot,
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Hi George, the thing is tat the only option I have to select is CUSTOM. (This is happening in this particular file only, in other files I have by default REFERRED DRAWING selected )
Hi Erika, did you attached a screen shot? Because I don't see any.
Thank you,
F.S.
David Maudlin
fransole:
I think you need to change with Marker Reference to: from The selected viewpoint to The selected drawing. Your marker is referencing a viewpoint which cannot be on a layout (hence no reference IDs), you need to link the marker to a View that has been placed (or can be placed) on a layout. This is the difference between the Project Map and the View Map in the Navigator.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
