2011-08-3110:29 PM - last edited on 2023-05-1903:34 PM by Gordana Radonic
Camera view with renovation filter
2011-08-3110:29 PM
I am trying to show a camera view that reflects the 'new' status on a project using the renovation filter. While the 'new' status appears correctly in the plan view, when I generate the camera view, it shows the 'existing' version.
I looked for the renovation tag related to the camera but couldn't find it. Is there some setting that I haven't found yet?
Renovation Status does NOT flow thru from Plan window to 3d Window...
But you can simply CHANGE the filter once you're in the 3d Window.. I am not sure that you can make it stick without creating a VIEW or 3d document and a view..
Though the 3d renovation filter should not change again until you change it in the 3d window (meaning... changing it in the plan window will not affect the 3d window)
