Camera view with renovation filter
Paul Adams
I am trying to show a camera view that reflects the 'new' status on a project using the renovation filter. While the 'new' status appears correctly in the plan view, when I generate the camera view, it shows the 'existing' version.
I looked for the renovation tag related to the camera but couldn't find it. Is there some setting that I haven't found yet?
Thanks,
Paul Adams, AIA, LEED AP
AC17
iMac, 4G RAM
MacBook Pro, 2G RAM
1 REPLY 1
vfrontiers
Renovation Status does NOT flow thru from Plan window to 3d Window...
But you can simply CHANGE the filter once you're in the 3d Window.. I am not sure that you can make it stick without creating a VIEW or 3d document and a view..
Though the 3d renovation filter should not change again until you change it in the 3d window (meaning... changing it in the plan window will not affect the 3d window)
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
