Can't print elipse using publisher
Steve Jepson
I think this is an old problem but I couldn't find any info about it.
Using ArchiCAD 14 I Published some .pdf's. Some of the elipses are missing. ( bathroom sink)
I printed the layout selecting Adobe Acrobat as the printer and it works fine.
What is the problem?
1 REPLY 1
There are posts about it somewhere.
You will find your basin object is mirrored.
There is a bug with the built in PDF converter that doesn't print arcs that have been mirrored.
From memory this was a bug some couple of versions ago as well that got fixed in a hotfix.
Here's hoping this will be as well.
It is not possible to un-mirror an object if it is not symetrical.
