We value your input!
Caps Lock select/ deselect
In older versions of ArchiCad one could cycle through items that are on top of each other by setting the caps lock on. I understand there is a new way to do this but I have not been able to figure it out. Sometimes holding the caps lock key down seems to work and sometimes not. What is the trick? Thanks in advance.
David Rulon
Dell Athalon xp1500 533mb ram
Windows 2000
AC 8.1.0.1307
10 REPLIES 10
Erika Epstein
You have to use the arrow tool and then put it on the "1" key.
Many of us still wish for the old way.
AC9 is the same.
Try setting your own shortcut key
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
In AC9, you hold down the CTRL & SHIFT keys simultaneously. It's (big surprise) in the "New Features Guide", under Revised Selection Methods.
Richard
AC26 (since AC6.0), Win10
__archiben
Erika wrote:
AC9 is the same.
archiCAD 9 will scroll through overlapping element nodes and overlapping element fills. once you get used to using 'quick-select' and the various modifier keys that go with it, i believe that it is a vast improvement on any method of selection we have had previously.
~/archiben
b e n f r o s t
Erika Epstein
nevermind,
still learning to type
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
__archiben
Erika wrote:
nevermind,
just read my post back through - it sounds a little brusque. sorry, it wasn't intentional.
~/archiben
b e n f r o s t
Erika Epstein
you weren't brusque at all;
if you had caught my unedited posts, you might have noticed that I was typing the wrong combo of keys and figured there was yet another new WS setting I was missing.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Still miss the old days...
__archiben
and how long have you been using the 'quick select' of archiCAD 9?
~/archiben
b e n f r o s t
I am not sure what you mean by the "1" key. Could you please explain more. Thanks.
