2011-02-21
07:01 PM
2023-05-31
10:16 AM
Rubia Torres
2011-02-21 07:30 PM
2011-02-21 08:12 PM
2011-02-21 09:06 PM
2011-02-21 09:22 PM
2011-02-21 09:47 PM
2011-02-22 01:00 AM
2011-02-22 02:12 AM
Daniel wrote:Ha! That's great!
That was it, for reasons unknown it had been changed to 0 seconds! No one in the office is confessing to be the author of the prank.
Thanks!
2011-02-22 02:48 PM
Karl wrote:True if your Working Units are set to feet & fractional inches, not if they are set to feet & decimal inches. I did not test the other options.
If you aren't aware, the "/" (forward slash) key is the same as the inch symbol, so 3/ is 3 inches.
2011-02-24 07:31 AM
David wrote:I work mostly in metric but do go into "Imperial" sometimes. Thanks Karl and David for the tip and warning respectively. I used to type (for example) 0-3 to get 3 inches but 3/ is certainly better.Karl wrote:True if your Working Units are set to feet & fractional inches, not if they are set to feet & decimal inches. I did not test the other options.
