Hi All,
I have received an explanation from the developer. There are some lines of code in the add-on which, depending on the localization, switches the dialog unit to inch for these wizard settings.
This explains why it couldnāt be reproduced in the INT version. I have registered the defect into our system (please refer to it as DEF-1200). Hopefully, this issue will be fixed soon!
Thank you once again for spotting the bug! Should you have any further questions, feel free to let me know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
