Got a minute? We appreciate your feedback:
Graphisoft Learn survey
Change in Floor Elevation Label?
leones
Any suggestions on how to create a custom Label with Auto-Text for indicating a change in floor elevation? from slab to slab or ramp landing to floor?
I've attached an image from an autocad example below
1 REPLY 1
Podolsky
Ace
There is no availability currently. Label can be attached and reads parameters only from one element. In given example it is necessary to receive / process information from two elements.
