Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Changing past issues/transmittal
Sophie Hoppe
HI
I need to re-issue the first issue with all the layout. I can then recreate the subsequent issues. the problem is how to change the issue date ?
thanks
13 REPLIES 13
Agree this is the best approach to revision management with handling properties in the scheme of not only the Transmittal Set but also in the Changes.
Personally, I have put in manual properties in the scheme for Issue Date into the Transmittal Set and Issued by into the change. I did this so different people could be responsible for the changes on separate drawings, but the person issuing or transmitting the collection of changes would then control the date.
Also, computers have never been named the way you want them to be, and you may be creating the issue and transmittal the day before you want to actually issue them. This workflow I have had in place since 2014 when it came out in Archicad 18.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
Ryejuan
thankyou.  I have a problem with the submittal letter. It doesn not update to the latest revision number.
ā€ƒ
thanks
You will need to add a change to the layout for it to revision up. Or you need to have the setting that all layouts in the transmittal are to be revised up.
Director | Skewed
how are you getting this Drawing Register-looking document in Archicad?
are the columns showing the previous drawing issues (12/9, 16/9) automatically generated from the Book Settings with their Revisions?
AC25 | Win11 | 64Gb RAM | Intel i7 13700F | RTX 4070 Ti
https://discord.gg/XGHjyvutt8
