Kamelite
Changing the units i elevation
I'm pretty sure this is a simple thing, I just can't seem to figure it out.
In the picture below, I have an elevation, and I need to label those windows with dimensions. So far so good. But I want to display them as decimeter-values, so that the label shows 10*19 instead of 990mm*1880mm..
[attachment=0]vindusdimensjoner.jpg[/attachment]
How do I make this happen?
.Thnx, Kamelite
Windows 10, Archicad 27,28 and 29
1 Reply 1
David Maudlin
Kamelite:
If that is the Dimension Label 23, go to the Symbol Label Custom Settings > General Settings... tab, it has Show Units > Linear > mm, cm, dm, m, inch and by Project Preference options.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
