Tracey Sharples
Cladding isn't joining seamlessly at corners in elevation and 3d
I'm having a problem getting the cladding on my walls to wrap corners seamlessly in elevations and 3d. I have checked that corners are joining properly and I have checked the priorities. The odd thing is that some corners are showing correctly and others aren't - despite having the same settings as far as I can tell. In the image attached the corner is great on the lower level but is wrong on the upper level. Hope someone can help.
Archicad 26 Win11
1 Solution
Srinivas
Did you check if the "End Surface: Override using adjoining walls" option? see attached.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Go to post
Srinivas
ArchiCAD Service
Mac, Windows 11
Tracey Sharples
Thank you so much! The 'end surfaces' boxes were all ticked but 'align texture to edge' was also ticked on some. Such an easy solution but one that had eluded me for a long time.......... thanks again.
Archicad 26 Win11
