vfrontiers
Clones of Layouts
Wouldn't it be nice if we could CLONE layouts into publisher so we would never forget to add that sheet to the PDF or Print set?
It never fails that I need to add a sheet to my Construction Docs after I've already created my PDF Publisher. If we could CLONE Layout Subsets, then my publisher would automatically track those added sheets.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
20 Replies 20
Achille Pavlidis
Erwin wrote:
Even when overridden to have empty background, won't the fills still remain?
No actually they don't.
Erwin wrote:
I don't think you can mass relink drawings internally. You may be able to mass relink to a different folder if you would publish to PMK files, maybe. But leaves you with same problem: relinking all the views to begin with.
I assume you need your layout information in the DWG, or you could just publish the views as DWG.
Yes you can't mass relink. What I need is a function similar to the cloning of views where the same layout (with all the info, revisions etc) gets cloned but with different model view options
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
