Commas In Dimensions?
Hi, when i dimension i am getting annoying commas in the actual figure, how can i remove this?
11 Replies 11
Excel can show whatever format you want it to show, whatever your System Settings are. Shouldn't ArchiCAD do this too, in Project Preferences?
If you happen to be working on a metric project and an US project, the current 'solution' is switch the system settings every time you switch file. That doesn't seem right.
Brett Brown
GeNOS wrote:
Brett wrote:
Yes you can. In XP goto Control Panel/Regional and Language/Regional Options and get rid of comma there.
im in that options window but what do i do to remove the comma?? i tryed customize, but when i remove the comma it says its an invalid selection
You delete the comma in "digit grouping symbol" and replace with a space. Then change "digit grouping" to the option without the space.
