Views, layouts, publishing: seamless Archicad documentation
SOLVED!
Control pen set of stories below or above
like with elevation and section tool you can control thickness and color of lines in the background. Can i do that with my plans? fade the story below(or above) the one i am currently on.
1 ACCEPTED SOLUTION
Solution
Eduardo Rolon
You will need to create 2 rules per floor. One to GO stuff above and one for below.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
4 REPLIES 4
Eduardo Rolon
You can use Graphic Overrides to control both.
AC29 US/INT -> AC08
another Moderator
thanks for replying,
i couldnt find any sort of criteria inside the graphic override menu for home stories, can you point me in the right direction?
Solution
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
i see, i was trying to find home story criteria while looking for all element types. thanks!
