ā2010-12-06
07:54 PM
ā2023-05-19
12:10 AM
Gordana Radonic
ā2010-12-06 07:59 PM
ā2010-12-07 02:23 PM
lec1212 wrote:You should be able to copy the 2D elements from the section to the plan (or another window), place a new section, then copy the 2D elements from the plan to the new section, if all else fails. You would have to redo associated dimensions.
Of course I could delete the marker, but then I'd have to redraw my two D annotations to it all over.
ā2010-12-07 08:25 PM
David wrote:Thanks for the replies.lec1212 wrote:You should be able to copy the 2D elements from the section to the plan (or another window), place a new section, then copy the 2D elements from the plan to the new section, if all else fails. You would have to redo associated dimensions.
HTH,
ā2010-12-08 02:15 PM
lec1212 wrote:lec:
I copied the 2D work to floor plan (for later past) and then tried to set new section marker exactly as previous one, but somehow I could not get new section marker to be EXACTLY as the old one. Part of my problem was that when I tried to zoom in to place a small line to mark exact extent settings of old marker, marker would not be visible even though it was selected...
