James Hawthorn
Current Renovation Filter
I am trying to paste some elements from one plan file to another plan file and I get this. It doesn't tell how to turn off this filter.
4 Replies 4
David Maudlin
James:
Check which Reno Filters (Existing, Demo, New) are set to Show in the original file and make sure this same filters are visible in the second file.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
James Hawthorn
Hi David,
The file Im copying from is set to Project Completion. The file I'm copying to doesn't have that option.
I don't see a profile tab. I also don't see your example.
James
David Maudlin
James:
Here is the Reno Filter Options:
The Reno Filters are like Layer Combinations, they can differ between files, so if you may want to set up a matching Option for the second file. 
And here is my signature, I don't know why it doesn't show for you (the Community has recently been upgraded and I cannot find where under My Settings the signature is set, maybe someone else knows). You'll find other users with similar signatures:
Hope this helps,
David
Erik Bjornhage
If you set up a RenovationFilter that shows all objects regardless of RenovationStatus - then you should be able to paste anything into your active view since they are not hidden by the settings of the RenovationFilter.
Erik Bjornhage : SwedishChef, INSIKT Digital Sapiens, Gothenburg, Sweden - Architect : Digital Development : Graphisoft Cert. BIM-Manager - Eriks LinkedIn : INSIKT
ThinkPad P1 G7; Ultra9 185H; 64 GB; RTX 4070 [8GB] : AC12 - future
