Curtain wall label with global dimensions and ID
Hi!
Is there a solution for labeling curtain wall elements as a whole (not the subparts) with the following parameters: global width, global height and ID
Sadly, the opening label 24 does not work with curtain walls, and I am looking for a similar option as for doors and windows.
thanks in advance!
1 REPLY 1
Yes, it is possible to do with the Text/Autotext Label.
In the following screenshot, I placed an associative Label for the Curtain Wall and displayed its "Element ID", "Length", and "Height" parameter as Autotexts.
