Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
SOLVED!
Cut timber beams with an X
Strawbale23
Back to using AC after 6 years away...
What is the way now to make  cut wood beams show an X in section??-
I did a search but the last conversation was in 2011.
Thanks
AC26
https://www.zendsign.fr/
1 ACCEPTED SOLUTION
Solution
Patrick M
Mentor
best bet is still a custom profile with 4 triangular fills. The profile manager no longer "heals" fills automatically in section the way it did 6 years ago, so you can use a single fill (building material). You can also set a range of horizontal/vertical stretch parameters, so you only need a single profile to cover all square cut timber for beams/joists/etc.
3 REPLIES 3
Solution
Patrick M
Mentor
OK, so its still the same solution from 10 years ago!
I had a false memory of reading that GS had updated the beam tool to integrate this feature.
AC26
same solution, but it works better now. I still remember drawing profiles with a 1/64" gap between fills so the section didn't "heal"
