Dead Line Help: Publishing in PM to DWG, Lost Title Block...
I am reposting this again,
I just tried to publish my PM drawings to DWG, when I open the DWG's in AC to check for correct translation I do not see my title block or how I cropped the plans in PM. But it prints fine from PM. Where am I going wrong?
Thanks,
Joseph Harouni
7 Replies 7
joseph-
plotmaker entities go into AutoCAD's paper space. this is where your titleblock is. at the autocad commandline, type "ps" or "tilemode=0" or use the menus to select a paperspace view of your model. my guess is that AutoCAD opened the file in model space.
hth
wes
Weston wrote:
joseph-
hth
wes
Thanks for the reply, I am trying to check to see if the file translated correctly by opening it in ArchiCad. I do not have AutoCad, I would like to check it before sending it to the client. Can paper space be viewed in ArchCad? Should Be!
Thanks,
Joseph
Steve Jepson
wes
Thanks for the reply, I am trying to check to see if the file translated correctly by opening it in ArchiCad...Joseph
Do you have a .dwg viewer like VoloView?
Steve wrote:
wes
No I do not, does AC9 have the capability of showing the paper space?
Thanks,
Joseph
8.1 can view paper space.
Open any drawing or a blank document and set the floor plan scale at 1 to 1. Select and open the DWG. In the translator, under the "Settings in Selected Translator" section, select "Open Options" and you will see the options under Import Drawing Data From. Select "Paper space with Viewport Contents" and open. The drawing will then open in "Paper Space" with the sizes in the drawing at a 1 to 1 scale with the plot sheet for your review.
Hope this helps.
Steve Jepson
yes
Hope this helps.
Thanks Family,
It worked but intresting enough not with merge comand & also with 1:1 canot see the text but with 1/4" = 1' 0" I see the text but the walls do not measure correct? Just do not understand DWG!?
Thanks,
Joseph
