ā2004-09-29
05:59 PM
ā2023-05-26
12:15 AM
Gordana Radonic
ā2004-09-29 06:58 PM
ā2004-09-29 07:09 PM
Weston wrote:Thanks for the reply, I am trying to check to see if the file translated correctly by opening it in ArchiCad. I do not have AutoCad, I would like to check it before sending it to the client. Can paper space be viewed in ArchCad? Should Be!
joseph-
at the autocad commandline, type "ps" or "tilemode=0" or use the menus to select a paperspace view of your model. my guess is that AutoCAD opened the file in model space.
hth
wes
ā2004-09-29 07:23 PM
ā2004-09-29 07:30 PM
Steve wrote:Thanks for the reply, I am trying to check to see if the file translated correctly by opening it in ArchiCad...Joseph
wes
ā2004-09-29 07:43 PM
ā2004-09-29 07:47 PM
ā2004-09-29 08:25 PM
tprokop wrote:Thanks Family,
8.1 can view paper space.
Open any drawing or a blank document and set the floor plan scale at 1 to 1. Select and open the DWG. In the translator, under the "Settings in Selected Translator" section, select "Open Options" and you will see the options under Import Drawing Data From. Select "Paper space with Viewport Contents" and open. The drawing will then open in "Paper Space" with the sizes in the drawing at a 1 to 1 scale with the plot sheet for your review.
Hope this helps.
