Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Ivan Myers
Deadline coming up Please Help I lost my Layout to PDF?
Hello,
I accidentally deleted one of the PDFs in the Layout to PDF list. And the whole set disappeared and I cant seem to repopulate the Layout to PDF option so I can publish it. What did I do? How do get all the sheets to publish as one PDF?
Thanks Ivan
Archicad 19 on a Mac.
Designer/ Drafter
ArchiCAD 26 on 27" Mac
Go into the organizer - Windows>paletts
Then drag the layout folder over into the right hand column as screen shot.
To publish as one pdf under format tick the merge to one pdf box
Ivan Myers
Rogerdodge,
You are a life saver! Thanks so much for the quick reply. I'm still transitioning from Revit to Archicad and thins are better for sure but just different enough and called different things to make some things mystifying.
Much Obliged!
Ivan
Designer/ Drafter
