2024-03-10
03:56 PM
2024-03-11
04:53 PM
I am completely new to ArchiCad and I started following a tutorial on YouTube during which I accidentally deleted the section markers (I think). Regardless, the section markers have disappeared and I don't know how to restore the interface to default.
How do I get the section markers back in the ground floor view?
Thank you in advance.
See attached image.
Operating system used: Mac Apple Silicon 14 Sonoma
Solved! Go to Solution.
2024-03-12 03:36 PM
But. is that the template file after you accidentally deleted the sections?
What happens when you open a new template?
If they are still missing, then you somehow managed to delete the sections and re-save as the default template - hard to do accidentally, but not impossible I guess.
It is very easy to just add new section markers.
2024-03-12 03:41 PM
Thank you @Barry Kelly and @Laszlo Nagy for your help.
I will create the section markers manually instead.
