sarahric
Demolished elements in planned status elevation
Where I have an existing wall with an existing door or window, and just that door or window gets removed, then the wall hole is automatically infilled in "planned status". This then leaves a line around the element that was removed.
I am trying to produce "as built" drawings so need to not see this line. How can you remove this line? Image attached of existing wall with bigger window removed (smaller window is new).
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
10 Replies 10
sarahric
Curious. This has worked, thankyou.
