2019-12-10
		11:17 AM
		2023-05-30
		12:23 PM
			Rubia Torres
2019-12-11 12:32 AM
2019-12-11 03:58 AM
2019-12-13 12:36 AM
2019-12-13 01:07 AM
2019-12-13 02:42 AM
2019-12-13 02:48 AM
2019-12-13 04:04 AM
2019-12-13 04:11 AM
EDDY wrote:Since it shows up in these (4) views ok, are you seeing that the the only place it does not show up as expected is in the Layout ?
Hi Steve
Thank you,
I have done all the settings but it still seems to be partially lost, strangely this was tried on my friend's computer in another place using Windows OS also experienced the same thing with a trial file.
I can't understand where I made a mistake?
I used ArchiCAD 22 to try this as there was no problem.
ArchiCAD 23's initial hotfix does not know when it will be issued whether this problem will be included in the repair or this is only my problem that I have to face.
It's quite frustrating while I can't go back down because migrating from AC23 to AC22 will create many new problems for adjustment, this will waste a lot of time
Is there anyone from GS who can explain this is this really a Bug? or I made a mistake?
I tried to switch to using a PC computer and experimenting with new files with the method I used to do that was no problem, still the Details on the View Map will disappear some lines or the fill will look messy.
2019-12-13 04:44 AM
