Detail Tool
Gisele
How can I set the Detail tool to Auto-rebuild a Model the away a section works?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
2 ACCEPTED SOLUTIONS
You can't.
Use a section instead - automatically updates and no lines and fills.
DGSketcher
Legend
To mark the location of the section on your drawings as suggested, you can Place a Linked Detail Marker.
You can't.
Thank you, Barry!
DGSketcher
Legend
