License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Details Change Color and Fills Change Pattern Occasionally
architect
My gray fill pens 19 & 113 keep visually changing to different pens 124 & 56, even when I select the fill it notes 19 & 113, so nowhere does it show 124 & 56 are my selected pen types.
*This image below is showing the color that it changes to, in no instance can I find this as the chosen color:
Also, fills change to the same hatch despite fill type/building material being different than it shows:
architect
The renovation filter was set to Proposed, I changed it to Existing, then back to Proposed. That fixed the issue, so I repeated that process for all of my details. Strange bug.. Thanks for your time @Ricardo Lopez
5 REPLIES 5
Ricardo Lopez
Hi @architect,
As it appears in your second screenshot, that cyan color is what you chose for pen number 104 (default description: Objects - Cut Fills).
Try to change that customized "ALL" penset in your details view.
Regards. -
M. Arch. Ricardo López
AC17-27 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Thanks @Ricardo Lopez , would you note why that pen number 124 is overriding my selected fills?
I'm only selecting/showing pen 124 as I figured out that is the pen that is overriding my other gray fills:
Is there a graphic override combination set in that view that is changing that pen for all the background fills...?
No graphic overrides are on.
architect
