architect
since ‎2023-07-03
‎2026-01-07
User Statistics
  • 48 Posts
  • 5 Solutions
  • 18 Likes given
  • 9 Likes received
User activity
Is there a way to adjust this at the landing? I want all the risers to move forward by 1" while keeping the landing at its 4'-0" dimension: Operating system used: Mac Apple Silicon
I create & export PDF B, with clickable hyperlinks, in Google Sheets.I place PDF B in Archicad on a sheet. I publish and PDF B hyperlinks are no longer clickable. Any solution, or workaround?I could have PDF A (Archicad) be a blank title block page Then, attach PDF B (Google...
Any solution to either of these issues would be helpful, if not they're wishes.They are only relevant to Complex Profiles.Have the Wall Tool info box read Total Height for Bottom & Top & not nominal.For instance, if the wall is 9'-0" from sheathing to floor joists, nominal r...
I always keep the SEO Palette open, I wish it could dock in my workspace like the Favorites palette etc. does
Wish - adjust a slab size width without switching to plan view.Why - ceiling & floor section edits, cabinetry that may has 5-6 stacked slabs where it's hard to determine which is which.
