Different dimension units within the same project
Sorry if this is a question with an obvious answer...in brief, I am trying to publish a layout dimensioned in decimal inches in a project which is overall in feet and fractional inches.
In AC14, within a project where the working units are set as feet and fractional inches, I have a layout I would like to publish with dimensions in decimal inches.
If I temporarily change the project settings > dimensions to decimal inches, the dimensions appear correctly in the worksheet (what I am trying to dimension is a hotlinked module with dimensions set as fractional inches), but not in the layout.
I have tried to manipulate whatever settings I could find to change the dimension units locally (to the layout), without success.
Is this something which I am unable to achieve because of ignorance or poor research, or should I be able to do this?
Thanks for any advice.
3 Replies 3
vistasp
Read up on how to save views in the View Map of the Navigator.
Excerpt from the reference guide:
Once you save the view, it will store the combination of the following settings:
• Layer Combinations
• Scale
• Partial Structure Display
• Pen Set
• Model View Options Combinations
• Floor Plan Cut Plane
Hope this helps.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Srinivas
Make sure you save your desired dimension units as a Standard in the Project Preferences and assign it to the view map placed on the layout.
Here is a tutorial on how to setup view map
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Thank you vistasp and Srinivas. That was a simple solution.
