Dimension Rounding
Gisele
Is there a way to automatically round dimensions?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
2 ACCEPTED SOLUTIONS
David Maudlin
Gisele:
If you are referring to the dimensions displayed by the Dimension tool, look at Options > Project Preferences > Dimensions... change the accuracy to what you want, then Store as... the dimension preference so it can be assigned to a View.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Open the View Settings for your drawing in the View Map and select the required dimension style.
https://help.graphisoft.com/AC/26/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC26_Help%2F140_UserI...
David Maudlin
Gisele:
How to assign a stored dimension to a view?
