2023-04-14 08:47 PM
Is there a way to automatically round dimensions?
Solved! Go to Solution.
2023-04-15 02:21 PM
If you are referring to the dimensions displayed by the Dimension tool, look at Options > Project Preferences > Dimensions... change the accuracy to what you want, then Store as... the dimension preference so it can be assigned to a View.
David
2023-04-19 12:05 AM
Open the View Settings for your drawing in the View Map and select the required dimension style.
2023-04-15 02:21 PM
David
2023-04-18 05:11 PM
How to assign a stored dimension to a view?
2023-04-19 12:05 AM
