2005-11-07
01:54 PM
- last edited on
2023-05-30
03:25 PM
by
Rubia Torres
2005-11-07 03:34 PM
2005-11-07 04:52 PM
2005-11-07 08:29 PM
2005-11-07 08:53 PM
s2art wrote:I have to agree with s2art, that the "Wrong" purple line looks correct to me, but there should be more of an option.... also useful if you rotate a plan 90 degrees on a sheet and want the dimensions to read correctly.
I seem to remember, when I was taught draughting (and that was a while ago too), that any text beyond the 90degree (vertical) angle should in fact be read from the bottom of the page. So your diagram showing "wrong" is actually "right".
It would be good to be able to do it both ways ofcourse, as conventions are different all over the world (and I'm hanging off the underside of the planet, so what would I know anyway?)
Might be worth a wish?
2005-11-07 09:02 PM
2005-11-07 09:19 PM
Is right, is it wrong…I don’t know…but at least I should have the freedom to choose…
It would be good to be able to do it both ways ofcourseand we are agreeing with you....
2005-11-07 09:28 PM
r wrote:Come on Rob, you know as CAD Manager you have repeat AT LEAST 3 or 4 times before anyone listens
I will repeat.....
"Not to get into a heated debate of what is right or what is wrong"
I don't want this to be Myching is better than YourChing....I am looking for freedom to rotate
2005-11-08 03:22 AM
r wrote:No need to explode the dimension.
actually in order for me to get the desired results I have to explode the dimension element and when I rotate text I need a -angle, for example in my left hand example that text is at -255 when I move it...it will rotate back to angle I don't want...so the lock does not work
